Camera motion triggering motion within BI
Ri22o
2,267
4,530
Indiana
I have started putting SD cards in my cameras and setting them to record motion, but I have noticed this is triggering BI to record. I assume it is registering this as an ONVIF trigger? Is there a way to disable to trigger for motion but keep the triggers for IVS rules?
nope
Whats wrong with having the SD card record the IVS triggers?
Not all of them have IVS rules set up, so I have turned on motion within the camera to record to the SD card. I did not know this would trigger BI as well.
So you were not using the cameras to trigger BI and was using BI motion?
If so turn off pull ONVIF triggers in BI on those cameras.
I use BI motion for everything.
I turned on camera motion just to record to the SD cards as a back up.
Some of the cameras are sending IVS/ONVIF alerts to BI, so I can't just turn it off all together.
I will turn off motion for now until I get IVS rules in place, and then just use those.
If you dont use the camera to trigger BI simply disable onvif triggers in BI. Done.
Can’t you make use of the recent updates re ONVIF to actually only trigger on events that you want?
Possibly. I do believe I downloaded that update but was waiting a bit since it seemed as if everyone was having issues with it.
