I am running BI 4 (latest/last version).
I have 6 cameras configured but only 5 are showing up in the main screen. Not sure where the 6th has gone? This is probably a user configuration error but I can't remember changing anything.
I know it's configured and added, it's just not listed. If I login remotely I can see it just fine along with the other 5 but if I login locally on the server it's not there. So I can't edit the camera properties.
If I try to add it again it says it already exists. It is also recording properly from it as I can see the clips from it. I just don't see the live view and am able to access it from the server BI application.
Any help on this would be appreciated.
Thanks
Thanks
