I finally installing my camera system. I'm looking for suggestions on cameras as well as the placement of them. I have a horseshoe driveway and I want to put two cameras at the entrance pointing up the driveway towards the house. These would be for license plate recognition. One camera will be near the telephone poles in the first picture and the second will be installed to the right near the bush in the other photo. I'm going to figure out some way to hide the cameras so they don't get stolen. Are these cameras good for what I'm planning to do? What would you recommend? Also, is there a good camera in a turret design as I think it would be easier for me to hide. Any suggestions are greatly appreciated.
empiretech01.com
empiretech01.com
EmpireTech 1/1.8" CMOS 4MP IR Vari-focal Bullet Network Camera IPC-B54IR-Z4E-S3
Expedited shipping is not available. 4MP 1/1.8" CMOS image sensor Built-in IR LED, the max. illumination distance is 120 m Deep learning algorithm Supports max. 512 GB Micro SD card Built-in MIC IP67 and IK10 protection Smart Motion Detection 3.0
empiretech01.com
EmpireTech IPC-B52IR-Z12E-S2 1/2.8" CMOS 2MP 5mm–60mm Ultra Low Light
2MP 1/2.8" CMOS image sensor Built-in IR LED, the max. illumination distance is 150 m Deep learning algorithm Built-in MIC IP67 and IK10 protection Smart Motion Detection 3.0
empiretech01.com
