- Aug 9, 2016
- 13
- 0
Hi,
I have a Dahua IPC-HFW2100 camera which has been working fine for two years, but it recently stopped working without me having changed any hardware or IP configuration.
I attempted to log on the camera's admin web interface through Dahua's ConfigTool using the IPV4 ip address, and got an "IP Address Modification" window saying "Note: Current device IP and PC IP may not be in the same network segment or the port setting is incorrect. Please reset and try again".
I was only able to log on the admin web interface using the MAC address. In the admin interface I went to Network > TCP/IP and noticed the IP Version defaulted to IPv6. Every time I switch it to IPv4 and hit Save, it goes back to IPv6.
Any of you have any idea how I could make it default it to IPv4, so I can use the camera again? I should note that I have reset the camera using the built-in button.
Thanks!
Thanks!
