- Aug 18, 2017
- 22
- 6
I have a hikvision clone camera I'm using with blueiris. The camera has worked well for a couple years. Recently, I migrated to a new blueiris server and shortly after the move, I've started having problems with the camera (the POE source also changed at the same time as the server). The camera will initially come up, it works for about 10 minutes and then goes offline. I've changed the ethernet connectors on both ends. Any other suggestions of things I can try? On my ethernet switch (Unifi POE enterprise switch), if I cycle the POE on the port, the camera will come back up for a few minutes and then drops out again. This also happens with the hikvision software, so the problem isn't related to blueiris. Any help is appreciated.
