I have 3 cameras in a group, called EastvaleNorth (192.168.1.56), EastvaleSouth (.58), and RainbowRidge (.59):
When I installed RainbowRidge a few days ago, I set it up in BI by cloning EastvaleSouth, since it's the same model, and then changing its IP assignment to .59.
Since then I've found that the "EastvaleSouth" instance in BI will sometimes spontaneously change from .58 to .59 and pick up the feed from the RainbowRidge camera instead:
I can "fix" it by reassigning it back to .58, but then I've missed a few hours of coverage on EastvaleSouth.
I'm tempted to just blow away the EastvaleSouth instance in BI and set it up manually, but I'm thinking that this might be revealing a bug somewhere in BI. Curiously, this started when I installed RainbowRidge as a clone of EVSouth. It worked fine for months before I did that. And the problem I'm seeing is with EVSouth, not with the newly-installed RainbowRidge instance.
Has anyone seen something similar?
