that is not an ip camera.this one looks nice
New DH 4K Starlight HDCVI Camera Smart IR Dome Camera Video Resolution 8MP Built in Mic IP67 Coaxial Camera HAC HFW2802E A-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
don't know if anyone has experience with that camera?
Don't buy China region hacked cameras.... Varifocal will allow you to zoom in precisely to get the proper field of view and the most pixelswhat are the advantages of varifocal ?
this dahua camera has 6MP but with fixed lens (not sure what is most suitable 3.6mm or 2.8mm):
Original IPC HDW4631C A 6MP Dome Network Camera POE H.265 IR 50m Built in Mic Metal Casing HDW4631C A Multi language with logo-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
or this one
Dahua IPC HFW4631K AS I4 6Mp Stellar Bullet IP Camera H.265 IR120m built in SD Card Audio Alarm interface IP67 POE CCTV Camera-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
so many models ... lol don't know what is most suitable
Check that the model number is available on the dahua international or us site. If it is not it's hacked.... There are a bunch of threads that discuss this.How to know if it is region locked? Ask the seller?
inferior sensors, sometimes inferior casing...but hey, you save a few bux...ok I have been reading a bit more on these region locked/hacked dahua cameras. Apart from not being able to upgrade them, what are the other disadvantages?
If you are not connecting the cameras to the internet, this should not be a problem right?
If a 2MP starlight zoomed to max (about 12mm) is not enough, even 8MP zoomed the same might not be enough. More zoom is more important than more pixels.
	thx for the reply. But the problem is zooming in will cover less "area" ... so more cameras will be needed then
