I have this one ip camera that goes on/off on hot days 85+ Fahrenheit. I can unplug it’s cable from my poe switch plug it back in and it works again for a little while… so a heat issue.
I switched it out with another camera of the same model that I know works fine located in the same building exposed to the same heat and powerd by the same switch and it to does the same thing. Now the other camera works fine at a different location in the same building.
I then tired a different poe switch and the issue is still there and different ports.
I have multiple cable testers and the cable passes.
In the colder temps I have zero issues it’s only later in the day when the temps rise and a simple unplug and replug the camera works again for a bit.
so it has to be the cable right? It’s the only thing left but why would a cable have these weird issue only on hot days.
