Got 2 cameras from Amazon. One was shipped from China and everything works. One was recently ordered from POE Depot. US version came with power supply
Same issue as people have mentioned. When in live view the volume is movable to right but the mute icon shows no matter what. No audio can be heard unless you enable 2 way audio
Chinese version works just fine and does not show mute icon
Anyone seen this where when upgrading to 5.2.5 audio still does not work. I used the remote upgrade option under Maintenance tab
China version using POE and US version using wifi. I don't think that matters but giving as much info as possible.
Audio settings for both are
G.711ulaw
Mic In
China version
Firmware V5.2.8 141231 on box
From WEB access
[TABLE="class: deviceinfotable"]
[TR]
[TD="class: rowheader deviceinfotd"]Model[/TD]
[TD="class: deviceinfotd"]DS-2CD2432F-IW[/TD]
[/TR]
[TR]
[TD="class: rowheader deviceinfotd"]Serial No.[/TD]
[TD="class: deviceinfotd"]DS-2CD2432F-XXXXXXXXXXXXX[/TD]
[/TR]
[TR]
[TD="class: rowheader deviceinfotd"]Firmware Version[/TD]
[TD="class: deviceinfotd"]V5.2.5 build 141201[/TD]
[/TR]
[TR]
[TD="class: rowheader deviceinfotd"]Encoding Version[/TD]
[TD="class: deviceinfotd"]V5.0 build 140714[/TD]
[/TR]
[/TABLE]
US Version upgraded to 5.2.5 on Box V5.2.3 141024
[TR]
[TD="class: rowheader deviceinfotd"]From WEB access
Model[/TD]
[/TR]
[TR]
[TD="class: deviceinfotd"]DS-2CD2432F-XXXXXXXXXXXXXXXXXXXXXXXX[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
G.711ulaw
Mic In
China version
From WEB access
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
[TR]
Model[/TD]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[TR]
[/TR]
[/TABLE]
