Problem camera is an IPC-HDBW5441F-AS-E2-3.6mm Firmware v2.840.15OG004.0.R Build date 2021-10-27
Anyone have a camera you set up that doesn't trigger on IVS? The camera works but doesn't do any detection. I am hoping a factory reset and reconfig will make it work again.
I reset the camera to factory defaults, problem is I had it on a VLAN with CIDR 192.168.3.0 and it reset to 192.168.1.208 (at least I think it did) I can't ping it anymore. I was going to get a RJ45 POE injector and connect the camera and my laptop to it in order to reconfigure the camera and then plug it back in the VLAN port.
Couple of questions:
1. anyone have a better/easier way to go about reconfiguring the camera? If
2. I checked the firmware page and I don't see an update for this camera. Should I reach out to Andy?
