N Norstar123 n3wb Feb 10, 2020 2 0 DFW Feb 10, 2020 #1 Installed camera 1.5 yrs ago on a 835' run. Worked great. Replaced camera no worky. 3 parts to this cable 1st = 350' 2nd = 400' 3rd = 126' Camera works at switch, 1st leg, 2nd leg but won't work on last 126' Any thoughts?
C concord Getting comfortable Oct 24, 2017 708 806 Feb 10, 2020 #2 I think you would get better feedback if you include the original cam/model and the new cam name/model ( coax or Ethernet, POE or POE+, NVR info, etc) Reactions: looney2ns
SouthernYankee IPCT Contributor Feb 15, 2018 5,176 5,338 Houston Tx Feb 10, 2020 #3 DO NOT DOUBLE POST YOUR QUESTION !
sebastiantombs Known around here Dec 28, 2019 11,503 27,723 New Jersey Feb 10, 2020 #4 Given the ethernet spec is 100 meters, say about 328 feet, you're lucky it ever worked at all unless it's an ePoE camera or you're using extenders.
