Question; do any cameras allow for the removal of the supplied network "tail" cable with female RJ45 connection without breaking the warranty of the unit?
The scenario is as follows:
Am planning a network camera installation using PoE cameras for my home.
The weather conditions in my area mean corrosion is real concern as RJ45 connections are not really rated for any sort exposure to humidity. So we would like to run a cable all from the PoE switch all the way to the camera and terminate it inside the camera. I see that there is "boot" supplied so provide some protection to the RJ45 connection but doubt this will provide adequate protection in the long term.
Hence we would therefore need to remove the "tail" that comes with the camera and terminate the cable we are running. Have access to very experienced network cable installer so have no issue running and terminating network cables. Note we can also solder and can do PCB board level repairs so working on the unit does present any problems.
Thanks in advance.
Thanks in advance.
