Hi,
I've been testing different mounting points for my cameras and it looks like directly mounted on the brick wall is the best option for all the cameras so far.
The main cameras I have are the IPC-HDW5231R-ZE & IPC-HDW5231R-Z. And I have the PFB203W wall mount brackets for them. https://www.dahuasecurity.com/au/products/productDetail/1044
These attach via a plate on the back.
What are people using to attach them to the bricks? Are they using the provided plastic anchors and screws or going for something stronger?
Like these AnkaScrews? Ramset 6 x 75mm Galvanised AnkaScrew Masonry Anchor
Or these DynaBolts? Which my crack the brick as it expands? Ramset 6 x 60mm DynaBolt Plus Flat Head Bolt - 4 Pack
Other options? Opinions?
Thanks
Thanks
