Camera 1 and Clone of Camera1 swap Bitrate. Normally Camera 1 displays the Bitrate, and the Clone displays 0 Bitrate, both show same Frames. When this swap happens Camera 1 motion detection does not trigger.
Setup: Camera 1 is configured to motion detect and record during the day and night profiles. The clone is configured to only record continuous during the night, no motion detection and no recording during the day. This usually works well, until the Bitrate is swapped, then I get no motion detected from Camera 1. If I disable the clone then re-enable it, the Bitrate goes back to Camera 1, and both cameras work as programmed.
Is there a way to lock Camera 1 as the primary and the clone as the secondary.
