Hey everybody,
i have a few SZSINOCAMS Model SN-IPC-4024 CSW running. All works fine so far.
But: If i change the RTS port from 554 to for example 2023, i can not access to the RTSP stream anymore.
If running more than one cam ist definately necessary to have a different RTSP port on each cam. Otherwise i can not connect all at the same time from outside.
Can somebody help me or does anybody has a good idear?
p.s. on privous/older firmwares it was possible. 3 of 6 cams have different RTSP ports and it works. Just the last 3 i bought only work with port 554.
Im pretty sure that router settings are corret cause configurated the porttriggering and so an as usual.
Best rgds,
Dennis
Best rgds,
Dennis
