Cam in, or right under mailbox
oxnor
Dec 11, 2022
24
21
MN
Hello, I'm looking to put in place a camera in my mail box, or right under, POE, that I plan to use for LRP (software based).
Any recommendations for that form factor?
I found this while searching, 8MP 4K POE Camera Metal Mini Box IP Camera ONVIF Security Video Surveillance IP Camera come with 3.6mm lens
and '
I have seen the recommendations, but looking to mount at the mailbox parallel to the road to have the best chance at capturing the plate.
thank you
Not a chance with a 3.6mm lens.
Plus you have no idea if you could set the shutter fast enough to capture plates- the cheaper one tend to not allow you to so that or if they do they will override it.
Further those are high MP on a small sensor size so it will be even more difficult.
Your best bet is a varifical turret. Many people have used this one with great success in a mailbox or on the mailbox post.
Reactions: JDreaming and oxnor
