Cam came with a password?
goneracin
Getting comfortable
Jul 2, 2023
193
411
On the Range
I bought one of these a few months back from andys Amazon store
Duhua IPC-T5241H-AS-PV 2MP 3.6mm FocalIts actually branded loryta
it appears to already have a password. I cant get in to set it up.
I have 7 other cams ive finally gotten enough of a clue on how to do this...lol.
This one i inputmy country, and it goes to the login screen, not the create a password
i tried admin:admin
admin:blank
I reached out to Andy, but havent heard back.
Im sure there is a work around, just unsure what that would be as i didnt get to give it an email or anything
+1^^.
Reset button should be under the door for the SD card.
After a successful reset, it should come back "up" with a static IP of 192.168.1.108
no luck, same thing. i type in my country qnd it goes to the login pqge, not the rest of initializing it
so i know its seeing it, it just isnt happy...lolI tried it for 20 seconds, a minute, plugged in not plugged in
OK you need the super duper reset LOL.
Unplug power
push and hold in reset
Provide power while reset held
Hold reset in for 2 minutes
Release reset button.
If it does it again, then try it in Edge
Unplug power
Didnt work
use Firefox
Worked fine
also had to use firefox for an amcrest i have
thanks again
