- Apr 25, 2018
- 119
- 47
So I found it hard to source CMR and outdoor rated, but came across this [marked as General Cable]. The vendor says "it's pure copper"
There's nothing in here that looks like it's CCA right?
______
General Cable GenSpeed 5e Series - Ivory
This premium cable is dual listed for CMR/CMX Outdoor
Designed to perform in extremely low temperatures (down to -40°C) without cracking to the jacket
Quality PVC jacket with sequential foot markers
CMX Outdoor rating, the cable can withstand exposure to sunlight and moisture
CAT5e network cables transmit at up to 1000 Mbps
Compatible with 100 Base T/1000 Base T (gigabit) networks
Solid core wire
Cable: 24AWG, 4 pair UTP, CMX, cUL/CSA certified, 350MHz
Meets Telcordia GR-3164-Severe Cold Impact Standard
ANSI/EIA TIA 568B
______
Solid core wire
ANSI/EIA TIA 568B
