- Jun 13, 2017
- 18
- 2
Up until now I've been using a basic toner and a pin tester for my wiring. I'm working on a site with 36 cams on a PoE switch. About 9 of those cams have constant signal loss events (hundreds a day per BI). I've replaced a couple of them, assuming it was the cams. The issue persists. I suspect it's the wiring. But a basic continuity tester won't do. I'm looking into professional cable testers from Fluke, Platinum Tools, IDEAL, etc. However, I don't know, if a fancy $500 copper tester will find my faults or, if I need a $2k qualifier. What do you use?
