So I swapped cameras and I got both working but the sunba doesn't move PTZ. I can focus it - but don't know why the motor won't turn despite the self test when powered on. I might try pulling the plug - The other wire works just fine (the original sunba line now on the hikvision).
I tried testing with my ideal linkmaster on the bad cable and it shows miswire and reversal. I just want to say there is no way in the world. I've replaced this end at least 4 times on both sides, this is camera 41 in my property so I can make cablesIm thinking there is a short in the wire. If you saw the jacketing on the one that works you would be shocked its been so shredded
So I changed out the sunba with another and it works just right. Don't know why or how but it does. Anyway Im done with this portion of the project
Thanks for all the help!
So I wanted to update here - I added a new camera with a short short run. Turns out I saw the same behavior. Totally pissed me off. I went and grabbed another switch and it turned on instantly and worked! I think the switch is messed up. Perhaps I reached the limits of the switch. Its an HP / Aruba 2530. I don't know but I just updated the firmware and the interface is all new and nice looking. Problem is I put the camera back on the aruba switch and it didn't work. I moved stuff over to the new switch which is better in that it is a 10/100/1000 where as the aruba is only 10/100. I am going to try the Trendnet I am using and see how it works but it isn't a great switch but is working better than this HP Aruba. Overall I would call it strange.
