I've got a few installs about to go up. All but 1 will be tucked away underneath trim, siding, etc. These runs will then enter the PFA130-E through one of the tapped conduit holes. I'd like to reduce this and ordered a cheap set of glands off Amazon. Turns out I don't think they'll fit. I saw people say the holes are 3/4" and "standard" fittings should work.. I ordered Robot Check
I wasn't aware that PG# is a thread type, and G3/4" was also a thread type. Some research seems to indicate they will not work. I was thinking I could teflon tape the threads to give some cushion, but if it's a large disparity, that's not going to work and I'll be gap filling with fixes.
TLDR:
I've got bare outdoor rated CAT6 entering PFA130-E from the side, need a waterproofing gland or other means to keep this watertight. Looking for recommendations.
TLDR:
