c# onvif ozeki very low framerate
Aug 17, 2018
6
1
Belgium
Hi
we're doing development with a hikvision camera and i would like to try to switch from the hikvision sdk to the ozeki onvif sdk. Although i'm encountering a slight problem, it's like a framerate of like 1fps and as soon as there is movement on the camera i get this:
is this normal? if not, how can i fix this?
Some more information: framerate on the camera is 20fps and resolution is 3840*2160
on the hikvision sdk the stream works on a very high framerate but not on onvif ozeki
Your attachment (screenshot?) is broken.
As that SDK is not free, you are not likely to find anyone with experience using it here.
Reactions: Tolting Colt Acres
