S swisscheese n3wb Mar 28, 2022 10 3 NJ Feb 6, 2023 #1 I want to be able to double click on a .bvr file to launch BI without entering the admin password every time. Can someone help? Tnx.
Edcfish Pulling my weight May 31, 2019 124 122 USA Feb 7, 2023 #2 I think this should do it.... Right click on the .bvr file, Select Open With. Check Always use this app to open Select More Apps Select Look for another app on this PC navigate to: C:\Program Files\Blue Iris 5\ Select BlueIris.exe Save and open ....if/when you want the Admin version of Blue Iris, it is C:\Program Files\Blue Iris 5\BlueIrisAdmin.exe
bp2008 Staff member IPCT+ Member Mar 10, 2014 13,386 15,395 USA Feb 7, 2023 #3 Probably what you are looking for is Blue Iris Settings > Startup > Always run as Windows Admin (use local_console user; no login prompt). Reactions: ldasilva, Edcfish, looney2ns and 1 other person
