I cant find a bullet version.Every company makes good and bad stuff.
Yes Dahua makes cheap stuff that is not on the ideal MP/sensor ratio to tap into the unknowing consumer chasing MP over quality.
There should be a bullet version of that camera, or at least there was.
Can you link me to a write-up or video on how to use Blue Iris without a NVR? I assume I’m gonna need external hard drives somewhere?
My neighbor with his 4K Lorex 8-pack from Costco has 6 of those cameras now laying around in the garage LOL, all replaced with 2MP and 4MP cameras.See this Home - Blue Iris SoftwareCan you link me to a write-up or video on how to use Blue Iris without a NVR? I assume I’m gonna need external hard drives somewhere?
If you are like most here, they will make for good paper weights when you replace them with better lower MP cameras LOLMy neighbor with his 4K Lorex 8-pack from Costco has 6 of those cameras now laying around in the garage LOL, all replaced with 2MP and 4MP cameras.
Keep in mind all NVRs are not created equal and if you got one with low bandwidth like 40Mbps, depending on how you run the cameras, you may only get to run 4 cameras on an 8 channel NVR.
Just because an NVR is rated for X number of channels doesn't mean it can actually support X number at full capacity. If you have to run the bitrate at 2,048 in order to use 8MP cameras and use the number of cameras the NVR is "rated" for, you have essentially downrezed them to below 2MP quality.
The camera would probably be ok indoors where you can take advantage of infrared bounce off of walls. Or kinda ok outside as an overview, but may not get much IDENTIFY out of it.
Is there a reason you want the bullet over turret? Most would prefer a turret and hate some of the better models are bullet only.
Here is an example of a turret not protected in the rain. The "hood" is only really needed if the camera isn't pointed down a bit. And if it is a problem, some have made one from PVC pipe.
Most here run BI without an NVR. As I said, a BI/PC is a NVR. You need a capable computer (laptops and NUCs are not recommended), HDD to store the video (which you would need for an NVR anyway) and buy a BI license. You will need POE switch to power the cameras and most add another ethernet card ($20) to isolate the cameras from the internet. Install BI and add the cameras and off you go.
It looks like the bullet version is now only in a varifocal, which is actually a good one to get.
This is the NVR i have.Several of my turrets are exposed and no issue compared to the bullet next to it.
Of course any rain event can wreak havoc to even a bullet camera with the hood. If the wind is blowing the wrong way it can temporarily put rain spots on your camera.
No different than an NVR is left on all the time, since the BI/PC is the NVR, yes it will be on all the time as well.
My concern is not power consumption but my computer itself. I have all my stuff on there. I’d like to shut it off when I’m not actively using it.OK that is a better NVR rated at 200Mbps bandwidth.
Folks here, including me, have used a meter to check the power usage of an NVR and computer for BI and they are comparable, and buy a newer computer and it will be even less.
An NVR is simply a watered down computer. I have an HP SFF computer and it isn't much bigger than an NVR. There is no keyboard, mouse or monitor hooked to it. I can place it anywhere and remote into it.
There’s not much info on their website about how to get a newbie started as far as exactly how to connect what hardware to what. “Blue Iris for Dummies”
What is a “business class 8th gen”? Dell laptop?Just like you are not checking email and surfing the net on your NVR, we don't recommend using your daily computer for BI either.
For $100ish you can buy a business class 8th gen that is basically brand new (most of them were bought in bulk and then sold off what they didn't need) and even less if you wanna buy used.
But if you already have the NVR, just go with that. And then at some point demo BI on your computer and realize what you are missing and you will gladly buy a computer just for BI lol
