Hey guys, I've been reading and watching a ton over the past couple of weeks, but there's just so much to take in. What I have in mind is a 6-camera setup with Blue Iris as my NVR. Here are my theoretical build items, so feel free to give feedback. I'm also attaching a drawing of the property and what I had in mind initially. Goal would be to identify anyone messing with my car or the tool shed (door is facing house), if the deterrent isn't enough. Google Maps isn't up to date, so I tried to draw it out as best I could with dimensions. Soffit sits about 14' off the ground, so that's most likely where they'd be placed.
PC: Dell Optiplex 7040 SFF Intel Core i7-6700 3.4GHz 8GB DDR4 256GB SSD Win 10 Pro | eBay (i7-6700) or Dell Precision 3430 Core i5-8500 3GHz 8GB DDR4 1TB Win10 Radeon Pro WX2100 SFF | eBay (i5-8500 w/Radeon WX2100) ? Is the GPU worth anything? DeepStack times?
Storage: WD Purple 4TB
PoE Switch: Cable: trueCABLE CAT5e Outdoor Shielded Direct Burial or is there any reason to go with CAT6 here?
Cameras: In Positions 2&5 I was leaning towards 4MP ColorVu turrets, 4mm? 2.8mm?
In Positions 1, 3, & 4 - maybe IPC-T2831TM-AS-S2 or IPC-T5442T-ZE in position 1? What about the 6th camera?
Should I get some sort of motion lighting on the side looking over the yard?
Please let me know what you think and if you need any additional info!
