Buffer Bottleneck?
mpl
Nov 6, 2023
24
13
Germany
Hello,
iv got on my Dahua cams this warning.
Cam1
Cam2
What doest it mean?
Setup:
Cam1
Cam2:
(Smart-codec = closed/off)
What should i change to close this warning?
I would first up the Receive Buffer in BI for every camera to 40, up from 6.2 you have.
If that doesn't fix it, then it is a network issue - do your cams pass thru the router to get to BI?
Thanks, iv changed to 40. At the moment no warnings more.
No, no router pass trugh. My cams and BI connected to an 8 Port POE Switch.
Router -> Switch -> CAM1
............................. -> CAM2
............................. -> BI
