Well, I have selected the second "profile" set up for each camera.....didnt see much CPU use drop in the brillcam cams.....but as soon as I saved the new setting for the DLINK...CPU dropped way lower - holding at 10-20% and ram is around 218 mb whjere it was almost 900 mb before. Wonder what I broke? LOLAre you using the substreams and using direct to disc and all the other items in the wiki....follow every one of these to bring CPU usage down. Trying to overthink another setting in BI to reduce CPU is in almost every instance an opposite effect!
Optimizing Blue Iris's CPU Usage
Blue Iris uses a lot of CPU time. In most Blue Iris installations, your CPU is the limiting factor which determines how many cameras you can have. As such, it is extremely important to optimize your configuration to ensure you can get the most out of your system while consuming the least...ipcamtalk.com
Not sure what "profile 1" in each case means....or where I would set up the parameters for the profile quite yet....
But it seems to have helped, especially with the DLINK
