Tried to update firmware on HeroSpeed S2L33M/IMX322 after update the web interface became inaccessable. Advanced IP Scanner shows that the camera is connector to the network and shows 192.168.1.166 IP address yet can't telnet nor open the webinterface. The last working firmware on the IP camera was S3L33M_IMX322_X_5.1.25.5. Tried to downgrade firmware through TFP without any luck using the following guide:
Any help would be appreciated, thanks in advance.
1. Rename the firmware to digicap.dav
2. Put the firmware under the same folder of this TFTP
3. Set the IP of computer as 192.0.0.128
4. Camera's IP can be anyone.
5. Run the tftpserv.exe
6. Power off and power on the Camera. The device will search the new firmware and upgrade it automatically.
7. Please wait until TFTP shows "Device [192.0.0.64] system update completed!" It takes about 5 minutes.
8. Close the TFTP before the camera reboots.
9. Camera will restart automatically after upgrading.Any help would be appreciated, thanks in advance.
