Hi experts, in our summer house i have a number of HFW1435SP-W.
One of them died, and while I replaced it with a newer model, I was trying to recover it for fun, learning, and reuse...
I do have a working firmware image and I went on with the steps in the posts here, not necessarily making the situation better,
At this point I guess the situation would need some expert advice:
The boot log says:
The partition table is:
And just in case the environment is:
- Cam was clearly stuck in a boot loop.
- I pressed the factory reset button but nothing happened.
- The cam went back to the default 192.168.1.108 and would respond to ping for a bit and then reboot again
- The Cam only showed port 3800 open.
- The well-documented procedure of restoring via port 3800 would not work, claiming failure to login. Tried the old credentials and the default credentials to no avail
- Connected the serial port and played with uboot
- Managed to successfully upload the new firmware via TFTP and run da/dr/dk/du/dw/dp/dc/up.
- After the uploads, not much changed. Still bootloop, still port 3800 only
- At this point i am afraid I probably got a wrong turn and improvised with uboot commands (e.g. rdefault, sync_uboot etc...)
- The boot log looks even worse now, and cam still not working
The boot log says:
-Boot 2010.06-svn3845 (Dec 18 2016 - 09:32:48)
I2C: ready
DRAM: 118 MiB
gBootLogPtr:00b80008.
spinor flash ID is 0x1940ef
partition file version 2
rootfstype squashfs root /dev/mtdblock5
fail to parse HWID
fail to parse bootargsParametersV2.text info
fail to init bootargsParametersV2
TEXT_BASE:01000000
Net: Detected MACID:00:12:34:56:78:9a
PHY:0x001cc816,addr:0x00
s3l phy RTL8201 init
sd update init:HWID is missing!
Using ambarella mac device
TFTP from server 192.168.254.254; our IP address is 192.168.1.108; sending through gateway 192.168.1.1
Download Filename 'upgrade_info_7db780a713a4.txt'.
Download to address: 0x5000000
Downloading: *
Retry count exceeded; starting again
Try again use backup_serverip
*** ERROR: `serverip' not set
Failed to get info.txt
Fail to get info file!
Init error!
Download Filename 'failed.txt'.
Download to address: 0x2000000
Downloading: *
state:ff,err_count:02
SPI probe: 32768 KiB W25Q256FV at 0:0 is now current device
## Booting kernel from Legacy Image at 02000000 ...
Image Name: Linux-3.10.73
Created: 2016-12-23 4:02:18 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1485054 Bytes = 1.4 MiB
Load Address: 00208000
Entry Point: 00208000
Verifying Checksum ... OK
Loading Kernel Image ...OK
OK
fail to load bootargsParameters.txt
fail to load bootargsParameters.txt file
get bootargs info failed
unknown phy memory type, use default
Starting kernel ...
unknown core,use back
>partition
name cs offset size flag fs_flags fs_type
MinBoot 0 0x0000000000000000 0x0000000000040000 0x00000000 0x00000000 0x00000000
U-Boot 0 0x0000000000080000 0x0000000000040000 0x00000000 0x00000000 0x00000000
hwid 0 0x00000000000c0000 0x0000000000020000 0x00000000 0x00000000 0x00000000
partition 0 0x00000000000e0000 0x0000000000010000 0x00000000 0x00000001 0x00000001
Kernel 0 0x00000000000f0000 0x0000000000180000 0x00000000 0x00000000 0x00000000
romfs 0 0x0000000000270000 0x0000000000150000 0x00000000 0x00000001 0x00000002
web 0 0x00000000003c0000 0x0000000000680000 0x00000000 0x00000001 0x00000002
user 0 0x0000000000a40000 0x0000000001030000 0x00000000 0x00000001 0x00000002
updateflag 0 0x0000000001a70000 0x0000000000030000 0x00000000 0x00000000 0x00000000
config 0 0x0000000001aa0000 0x0000000000070000 0x00000000 0x00000003 0x00000004
product 0 0x0000000001b10000 0x0000000000010000 0x00000000 0x00000001 0x00000002
custom 0 0x0000000001b20000 0x0000000000020000 0x00000000 0x00000001 0x00000002
backupker 0 0x0000000001b40000 0x00000000000e0000 0x00000000 0x00000001 0x00000002
backupfs 0 0x0000000001c20000 0x0000000000050000 0x00000000 0x00000001 0x00000002
data 0 0x0000000001c70000 0x0000000000100000 0x00000000 0x00000003 0x00000004
user1 0 0x0000000001d70000 0x0000000000290000 0x00000000 0x00000001 0x00000002
MinBoot mountcmd:
U-Boot mountcmd:
hwid mountcmd:
partition mountcmd:
Kernel mountcmd:
romfs mountcmd:
web mountcmd:mount /dev/mtdblock6 /mnt/web/
user mountcmd:mount /dev/mtdblock7 /usr/
updateflag mountcmd:
config mountcmd:mnt_jffs2 /dev/mtdblock9 /mnt/mtd jffs2
product mountcmd:mount /dev/mtdblock10 /mnt/pd/
custom mountcmd:mount /dev/mtdblock11 /mnt/custom/
backupker mountcmd:
backupfs mountcmd:
data mountcmd:mnt_jffs2 /dev/mtdblock14 /mnt/data jffs2
user1 mountcmd:mount /dev/mtdblock15 /mnt/user/
>printenv
bootargs=console=ttyS0,115200 mem=118M root=/dev/mtdblock5 rootfstype=squashfs init=/linuxrc
bootcmd=sf read 0x2000000 0xf0000 0x180000;bootm 0x2000000
bootdelay=3
baudrate=115200
ethaddr=00:12:34:56:78:9A
ipaddr=192.168.1.108
serverip=192.168.1.1
autoload=yes
gatewayip=192.168.1.1
netmask=255.255.255.0
ID=000000000000000000
da=tftp 0x02000000 dhboot.bin.img; flwrite;tftp dhboot-min.bin.img;flwrite
dr=tftp 0x02000000 romfs-x.squashfs.img; flwrite
dk=tftp 0x02000000 kernel.img; flwrite
du=tftp 0x02000000 user-x.squashfs.img; flwrite
dw=tftp 0x02000000 web-x.squashfs.img; flwrite
dp=tftp 0x02000000 partition-x.cramfs.img;flwrite
dc=tftp 0x02000000 custom-x.squashfs.img; flwrite
up=tftp 0x02000000 update.img; flwrite
tk=tftp 0x02000000 uImage; bootm
dh_keyboard=1
appauto=1
sysbackup=1
logserver=127.0.0.1
loglevel=4
autosip=192.168.254.254
autolip=192.168.1.108
autogw=192.168.1.1
autonm=255.255.255.0
pd=tftp 0x02000000 pd-x.squashfs.img; flwrite
stdin=serial
stdout=serial
stderr=serial
ethact=ambarella mac
Environment size: 1019/131068 bytes
