Hi all,
Great info on this forum. Thanks everyone for sharing.
I have another 5.3.0 update issue on a 3232F-IS (sticker says 5.3.0, but had 5.2.5 installed), though with a slight complication. The TFTP Auto-Updater is not functional because the camera is now 192.168.1.64 (Wireshark is picking up packets from this IP with direct ethernet connection). I suppose it is looking for 192.0.0.64 which is not the IP of the camera, so the auto updater will not function.
- Upon trying Putty to Telnet in to 192.168.1.64:23 I get connection refused.
- Upon trying to FTP in I get connection refused. Not sure I had the right port though?
- Upon using Tftpd32 port 69 to connect in, I get no response. Just sits on block #0 for a while, then timeout. Again- not really sure of the right port to use for this one.
- Of course, no web access or access via Surveillance Station.
Is there a way forward here? Perhaps persist with Telnet / FTP and try to get a connection that way?
Thanks
EDIT: SUCCESS! Use the 5.3.0 downgrader on this forum to fix this issue. Even though it is not a 5.3.0 camera, the downgrader fixes it. It is the only TFTP software and 5.2.5 combination that achieves the "updated completed" status for this camera.
Thanks
