Hi, This may be a question for an IT expert who understands how computers work, rather than an expert in Blue Iris, as it has got even Blue Iris support baffled.
This is the problem:
When increasing the number of web logins and the number of cameras, at a point the system starts to lower the frame rate massively, however there are no bottle necks at all. CPU, GPU, Network, Hard Drive, Memory all less than <50%, yet frame rate can go down from 20fps to about 1 frame per 15 seconds.
This is the hardware:
xeon dual processor with 32cores. Quadro P2000 graphics, 32GB memory
Cameras 16 x 8k cameras (which have to run on substream (1200 x 536 in order to have each one at 20fps.)
16 web connections to view each individual camera.
In the above scenario, if I change just one camera to 8k (main stream), then the frame rate will drastically drop on all cameras. If I switch 2 cameras to 8k then the 8k cameras will practically stop. By the time I have switched 4 cameras to 8k then the whole system stops. However as stated above, non of the resources goes over 50%, so my quest is:
Where is the bottle neck.
