Bosch Solution 6000 Installation PIR Sensors
Spizz
Jun 27, 2018
31
9
Australia
Hey all :)
I like installing things myself and I'm now tackling to install for the first time ever a new Bosch alarm system (Solution 6000).
I'm using only 4 sensors so I thought it should be easy.
I'm just a little confused with a couple of things and hoping someone will be able to tell me if I'm wrong or right.
On the PIR sensor, I wire it all up.... I place a 3k3 resistor on the NC and T terminals.... It's on the main board I'm getting confused.
Positive goes to positive, negative to negative. NC to the zone number (1 for example).... Where does T go? it goes to GND?
Might be a silly question, but it's my first time :)
