Hallo
My DS-2CD2132F-I has a bootloop.
Sometimes it takes off and I come to the web surface, can then see the settings and suddenly booted again.
Flashed Firmware is IPC_R0_EN_STD_5.3.0_150814, the Cam is an EU model.
Does anyone have an idea?
thx
billi
thx
billi
Code:
U-Boot 1.3.4-121219 (Apr 8 2015 - 14:34:29)
ARM Clock: 480MHz
DDR Clock: 336MHz
Hit Ctrl+u to stop autoboot: 0
|RCV UDP pack timeout|
Unknown command:null
booting from pri part...
load kernel...
load ramdisk...
init started: BusyBox v1.19.3 (2015-06-26 11:14:56 CST)
starting pid 378, tty '': '/etc/init.d/rcS'
Starting udev: [ OK ]
UBI device number 1, total 192 LEBs (24772608 bytes, 23.6 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi1_0.
pri_iUpgSuccCnt:0x1, sec_iUpgSuccCnt:0x1
UBI device number 3, total 32 LEBs (4128768 bytes, 3.9 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi3_0.
Check dir /davinci ok! (0)
UBI device number 4, total 32 LEBs (4128768 bytes, 3.9 MiB), available 0 LEBs (0 bytes), LEB size 129024 bytes (126.0 KiB)
waiting for /dev/ubi4_0.
Check dir /config ok! (0)
route: ioctl 0x890c failed: No such process
mount: mounting none on /proc/bus/usb failed: No such file or directory
/dav
map_size = 0x300000
nr_item = 3
addr_offset = 0x0 filename = orccode.bin
addr_offset = 0x200000 filename = orcme.bin
addr_offset = 0x2a0000 filename = default_binary.bin
mmap returns 0x40261000
loading ./orccode.bin...addr = 0x40261000, size = 0x19f02d
loading ./orcme.bin...addr = 0x40461000, size = 0x36374
loading ./default_binary.bin...addr = 0x40501000, size = 0x40000
u_code version = 2013/10/24 3.0
ln: /dev/rtc: File exists
=====check_config start=====
===main db is ok===
netprocess version: 1.6.1 [15:56:05-Jul 6 2015].
No need to recover kernel pri partition.
No need to recover ramdisk pri partition.
[11-01 13:46:01][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:01][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:01][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:01][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
infd read End
Unix bus 0 .
[11-01 13:46:02][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:02][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:02][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:02][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
==================PPPoE is disable!!!
[11-01 13:46:03][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:03][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:03][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:03][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:04][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:04][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:04][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:04][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
IEfile uncompressed.
[11-01 13:46:05][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:05][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:05][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:05][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:06][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:06][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:06][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:06][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:07][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:07][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:07][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:07][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:08][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:08][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:08][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:08][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:09][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:09][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:09][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:09][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:10][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:10][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:10][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:10][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:11][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:11][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:11][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:11][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
[11-01 13:46:12][pid:837][STRM_ANLS][ERROR] from daemon ack, dst not work len 0 , load_type is [10012]
[11-01 13:46:12][pid:837][UNI_IF][ERROR]65554:ipc_unix_call_service failed, ret = -3.
[11-01 13:46:12][pid:837][UNI_IF][ERROR]communicaite_to_davinci failed!!!
[11-01 13:46:12][pid:833][STRM_ANLS][ERROR]daemon can not find Dst process.load_type 0x10012 is_need_ack 1
Unix bus End
insmod: can't insert 'uart232.ko': File exists
davinci receive cmd_query_davinci_param.
S: cmd_query_davinci_param
powerLineFrequencyMode = 0
@@@motion PAL!!!!!!!!!!!!!!!!!
[11-01 13:46:14][pid:854][UNI_IF][ERROR]stream request out range 3(2)
version = 16777472
get 0-0-0-0.000000-0-0-0
version = 16777472
<init_run>3818:p_devcfg->ccdPara[1].capture_mode [17]
<MEGA_DSP>Platform Value:
<MEGA_DSP>Main mux type [0x4].
<MEGA_DSP>Sub mux type [0x4].
<MEGA_DSP>Thi mux type [0x2].
<MEGA_DSP>audio enc type[0x2].
<MEGA_DSP>voicetalk type[0x2].
<MEGA_DSP>Need PS SysHdr[0].
[11-01 13:46:15][pid:854][SYSINIT][ERROR]device not support RS485
[11-01 13:46:15][pid:854][HW_IF][ERROR]transfer_485_config_options error [options:57]
starting pid 868, tty '': '-/bin/psh'
BusyBox v1.2.1 Protect Shell (psh)
Enter 'help' for a list of davinci system commands.
# davinci receive cmd_query_davinci_param.
<DSP> DBG:init_dsp_lib() begin
<DSP> DBG:init_dsp_lib() end
[11-01 13:46:21][pid:854][DSP][ERROR][2]g_pdsp->audioTBShare.frameLen=80, g_pdsp->audioTBShare.totalFrame=128..
mknod: /dev/snd/controlC0: File exists
mknod: /dev/snd/pcmC0D0c: File exists
mknod: /dev/snd/pcmC0D0p: File exists
[11-01 13:46:21][pid:854][HW_IF][ERROR]<read_fixed_noise_info_from_flash> (CFG_MAGIC != read.magicNumber(ffffffff)
<DSP> DBG:setup_dsp() begin
<DSP> DBG:init_cmem_module:cached_size=33030144(31M),noncached_size=6815744(6M)
init_cmem_module:CMEM_cmdline=insmod /dav/cmemk.ko phys_start=0xc6600000 phys_end=0xc8c00000 pools=1x33030144,1x6815744
gdma Init Successful
b_fd=0,b_smd=1,b_scd=0,device_type=30,enableswaec=0
channel 1 is not 1 or 2<DSP> DBG:DSP start with Vout:Disabled,Audio:Disabled,VT:Disabled,MD:Enabled, vsync_guard:Enabled,vout_osd: Disabled, oversampling:Disabled, roi: Enabled, primacy: Disabled . hdr mode Disabled qr Disabled
<DSP> DBG:dsp_object.device_mode 0
<DSP> DBG:enc channel cnt 2, delay mode 0
Use CMEM buffer!
goto_idle done
pDspInitPara->VideoInitParam.capture_mode 125967385(width = 1920, height = 1080, fps = 25, interlace = 0)
device_type: 30, vitype: 21, fps: 25.000000
find_video_mode sucusss!! mode 125967385 p_mode_table[i].vin_mode 30 vin_object.vin_fps 25.000000 vin w 1920 h 1080
set mode 30 type 21
vin_mode 2304*1296 vin_mode_temp 2304*1296 vin_mode_temp2 2304*1296enc_chan_cnt=2
vin_object.vi_param chan = 1, fps/resolution/width/height = 25/4123/1920/1080
vin_object.vi_param chan = 2, fps/resolution/width/height = 25/4097/352/288
#######pDspInitPara vout enable 0
<VidThrd> DBG:update_encode_fps_ctrl: Begin chan=0,maxRate(maxFps)=25.000000,fps=0x1
<VidThrd> DBG:update_encode_fps_ctrl: f_frame_rate=1.000000,clockStep=45000
<VidThrd> DBG:update_encode_fps_ctrl:Finally chan=0,fps=0x1,fpsFlg=0x1,frmPerSec=1,fpsCounter=0,fpsCycle=25,g_md_interval 5 ms
<VidThrd> DBG:update_encode_fps_ctrl: Begin chan=1,maxRate(maxFps)=25.000000,fps=0x19
<VidThrd> DBG:update_encode_fps_ctrl: f_frame_rate=25.000000,clockStep=1800
<VidThrd> DBG:update_encode_fps_ctrl:f_frame_rate=25.000000,[25].clockStep=1800,[25]
<VidThrd> DBG:update_encode_fps_ctrl:Finally chan=1,fps=0x19,fpsFlg=0x1ffffff,frmPerSec=25,fpsCounter=0,fpsCycle=25,g_md_interval 5 ms
<VidThrd> DBG:update_video_config_param: chan=1,encode_type=1, (1920x1080), mirror type0, I inerval 50, bps 4014,quality 60 i_quant 29, complexity 1 rate_type 0,p_encode_param->f_frame_rate 25.000000,svc mode 0 qp 6
<chan 1> in None MotionJPEG, skip!
<VidThrd> DBG:update_encode_fps_ctrl: Begin chan=2,maxRate(maxFps)=25.000000,fps=0x19
<VidThrd> DBG:update_encode_fps_ctrl:Finally chan=2,fps=0x19,fpsFlg=0x1ffffff,frmPerSec=25,fpsCounter=0,fpsCycle=25,g_md_interval 5 ms
<VidThrd> DBG:update_video_config_param: chan=2,encode_type=1, (352x288), mirror type0, I inerval 50, bps 501,quality 60 i_quant 29, complexity 1 rate_type 0,p_encode_param->f_frame_rate 25.000000,svc mode 0 qp 6
<chan 2> in None MotionJPEG, skip!
overlay: start = 0x43d07000, total size = 0x100000 ( bytes)
b_rotate 0 overlay_level64 width 1920 height 1072
osd_width 1280 osd_scale_first 64 total 81920
b_rotate 0 overlay_level16 width 352 height 288
osd_width 256 osd_scale_first 16 sub total 4096
init osd area success
init osd memory ok
<OSD> DBG:Left=0 pChar->pos=4000000
<SetOsd()> line=0 y=64 line_char_count=16, valid char count 24,osd_lines 0
<SetOsd()> line=1 y=0 line_char_count=0, valid char count 0,osd_lines 0
<SetOsd()> line=2 y=0 line_char_count=0, valid char count 0,osd_lines 0
<SetOsd()> line=3 y=0 line_char_count=0, valid char count 0,osd_lines 0
<SetOsd()> line=4 y=0 line_char_count=0, valid char count 0,osd_lines 0
<SetOsd()> line=5 y=0 line_char_count=0, valid char count 0,osd_lines 0
<SetOsd()> line=6 y=0 line_char_count=0, valid char count 0,osd_lines 0
<SetOsd()> line=7 y=0 line_char_count=0, valid char count 0,osd_lines 0
chan 1, osd size 0 osd_size_changed 1
chan 2, osd size 0 osd_size_changed 1
b_rotate 0 overlay_level16 width 1920 height 1072
osd_width 1280 osd_scale_first 16 total 20480
<OSD> DBG:setosd ok
<OSD> DBG:setosd:END. chan=0,flgOsd=0x1, bStart=1
chan 1, osd size 0 osd_size_changed 0
chan 2, osd size 0 osd_size_changed 0
<OSD> DBG:setosd ok
<OSD> DBG:setosd:END. chan=1,flgOsd=0x3, bStart=1
<OSD> DBG:setosd ok
<OSD> DBG:setosd:END. chan=2,flgOsd=0x7, bStart=1
init osd success
<VidThrd> DBG:setup_video_input begin
<VidThrd> ERR:Please load source driver!
<VidThrd> ERR:set video source failed!
<DSP> ERR:setup_dsp:setup_video_input
[11-01 13:46:29][pid:854][DSP][ERROR]DSP ³õʼ»¯Ê§°Ü...
[11-01 13:46:29][pid:854][SYSINIT][ERROR]hwif_dsp_init error force sys reboot,ret=-12!!!!
ARM Clock: 480MHz
DDR Clock: 336MHz
AND REBOOT.....
