Boot stop serial ttl
Jul 7, 2021
14
4
Tehran
Hi
How to bootstop uniview 2122LR3 ipcam and change MAC address with serial port ttl tf232 with putty?
I try * and cntrl u but dsnt work
Plz help!
The bootloader is well past in your console screenshot.
Hint - in PuTTY you can copy / paste all of the screen rollback text into something like Notepad etc to edit and post much easier for you and the readers.
Use the 'Copy all to clipboard' option in the menu button at the top left of the window.
If you do that - you should be able to see if the bootloader shows how it can be interrupted.
I try cntrl B (putty) and it works and bootstop works properly and i config and change MAC address with (config ethaddr) successfully. Tnx for your attention!
Dahua: * button
Hikvision: cntrl U
Unv : cntrl B
For bootstop/.Tf232 serial port ttl
Dahua mac : mac and ethaddr saveenv
Hikvision mac : ethaddr saveenv
Unv mac: config ethaddr saveenv
Setenv mac for other devices/.
Reactions: alastairstevenson
