Bookmark / Mark timestamp within a clip ?
Jul 31, 2021
12
2
CZ
Hi,
Anyway to bookmark a specific time within a BI5 clip?
Not everything gets “flagged” via motion detection, and from time to time I would like to manual mark a specific point in the timeline and (preferably) give it a name.
I tried BI5website and the manual, but couldn‘t find anything else then flagging the whole clip.
Thx!
You can use the clipboard to create an item and - as of v5.6.0 - it will appear in the clips list timeline… or you can move it into the alerts list… See the last paragraph in the following excerpt from the help pdf.
You can also edit the item’s memo (via a right-click context menu, if I recall correctly).
