BNC male > female cable
Basjke
Jan 5, 2017
158
23
I need to buy 50 cm long BNC male > female cables to extend the BNC connection between balun and camera.
All I can find are coaxial ones, while obviously the one at camera and balun end are not coax.
Can I use them?
This is what is available here.
do you need to make adapt to Coaxial cable on one end? are you a bit short with your cable? and you just need a little more? that one you linked should work fine.
No it is to connect the camera to the Balun. I use a 50cm bracket to hang the camera, and cables are supposed to be hidden inside.
I just notice that in my listing is quoted 75 ohm, but they use 50 ohm coaxial lol
I'd just use a male/male cable with a barrel connector (double ended female).
Reactions: looney2ns
Just a habit out of convenience from the old days of ethernet on coax, 10Base2, and a lot of radio gear. I've got tons of barrel connectors laying around as well as crimping equipment for BNCs on RG58 and RG59.
Ok so I understand it is more based on personal reasons. I don't have all those tools, and although it will be doable, the male/female coax is easier to obtain.
Can I ask you, the cable I linked is IMO 50 Ohm instead of 75 Ohm as claimed in the listing.
Will that affect the quality of the signal with only 1 meter length?
Just from an engineering purist viewpoint, if it's a 75 ohm impedance source stick with a 75 ohm cable, RG59 or RG6. Any time you even put a connector in a cable you introduce an impedance mismatch, albeit a small one. A big one, going from 75 ohm to 50 ohm back to 75 ohm, can produce unexpected results due to the standing waves.
I notice that all cameras, including the Dahua's I own, and all Balun's have 50 Ohm connectors.
Why is that? I would have expected that at least a reputable company like Dahua would use 75 Ohm connectors.
