I know this is an IP forum but surely you guys do some co-ax work
We install mostly IP but sometimes do CVI on retrofits when we can not easily run new cable and have to reterminate some lines. Currently we use these compression style fittings that we put a boot on the wire first, strip the cable, put the BNC connector on, then use a tool to compress the the boot over the BNC Connector. I can't remember the name and a quick google doesn't pull them up.
The problem is they do not seem to make the connector in an RG6 and RG59 style, and on the RG59 cable, the connectors easily pull off. Plus the connectors come from one particular vendor and I want to make things a little simpler.
What does everyone else find to be the most secure, then easiest style of BNC? I was thinking crimp, I have a tech pushing for twist on.
Thoughts?
Thanks
Thoughts?
Thanks
