Hi all,
I have a pc running blue iris as well as the pc has a virtual machine on it with home assistant installed.
i recently changed over my network connection of the pc from wifi to a wired connection (wifi issues) and now it seems that home assistant can no longer access blue iris, and in fact I can’t access the biu3 interface at all on the local network except from the BI pc itself.
Running ipconfig on the BI pc shows that there are two Ethernet adapters one with ip of 192.168.1.65 which is the ip of the pc itself. The second Ethernet adapter shows with an ip of 169.254.80.79 which is the address of the BI webserver.
I presume that because they are on two different ip ranges that this is why I can no longer to connect to the BI webserver locally.
Any assistance with getting the BI webserver IP range back into my local network range would be appreciated.
I do not run remote access other than via connecting back into my home network via vpn.
