I have blueiris installed on a vm, the default card is the VMware 3d video card. When I install the GPU card, it sees two cards. The question is, does blueiris know to use the GPU card instead of the vga? If I disable the vga card, the screen does not give me enough of display resolution to make the screen bigger.
Thanks
Sent from my SM-S906U using Tapatalk
Thanks
