BlueIris problems on 4k monitor
pal251
Getting comfortable
Mar 15, 2014
1,019
137
I just installed BlueIris on my machine which is running at 4k resolution. The text is small for everything until you click the configuration icon and then the menu that pops up is normal size. Any ideas?
Thanks
If I can't get that working then I'll use the 49 incher next to the monitor
