In-case you missed this, BlueIris has added some great features but most importantly Sub-Stream support.
If you configure your Video feeds with a Sub-Stream, eg: /cam/realmonitor?channel={CAMNO}&subtype=2&authbasic={AUTH64} in the Sub stream (+Params) box then;
- BI uses the Sub-Stream for motion detection ect.. and the Main Stream for Direct to disk recording!!!
So in the past Bi with QuickSync used 25% CPU and 30% GPU, not it is using 5% CPU and 5% GPU!! and this is NOT using limit decoding which can be unreliable!!
Hardware decoding of H265 is also working for me, as well other other hardware decoding options which work under vmware!!!
Just pointing these updates out, in-case someone else missed them!!
PS: To check it is working correctly, in Blu Iris stats you should see Bit-Rates for the Sub-Streams which should be a lot smaller. You need to work out the correct Sub-Stream(+Paramaters) which for me a combination of "main stream" /cam/realmonitor then adding a question mark "?" follows by params from the main stream,but just changed the subtypenumeric value. If Ididn't add the ? or used / then everything seems to work, no errors but it wasn't using the sub-stream.
