- Jun 19, 2015
- 14
- 3
I have a blueiris install that has been running great on a Windows Home Server 2011 for several years. BlueIris has always been started "at startup" using the server's native task scheduler, so it starts without anyone logging in. This server also reboots once daily at a particular time.
A couple of weeks ago, I noticed that blueIris is not being started after the daily reboot as it always had. The Task Scheduler indicates that the task to start BI was started after the reboot, but BI was not running.
The funny thing is that every time I find BI down after the auto reboot, I manually reboot the server and BlueIris starts up normally, from the task scheduler, every time... so it sounds windows related
I just wanted to see if anyone else out there has run into simmilar problems with BlueIris on Windows Home Server, or if anyone has some suggestion on what I could look at to resolve this.
Thanks!
Thanks!
