- May 10, 2017
- 82
- 17
Hello, been running BI for quote some time, just noticed that the CPU (i7-2600k @ 3.4GHz) is running quite high sitting around 70% for BlueIris.exe, mem usage for BI is 2.5GB
I'm running 5 x IP Hikvision, Direct to Disk recording enabled. Cameras are running a mix of 15fts and 20fps.
Any ideas why this is so high? From the stats found on this page Blue Iris Update Helper I see many users running similar number of cams with far less CPU usage.
Any tips would be appreciated!
Thanks
Thanks
