I am using BI with HS (HomeSeer). In short, when a camera is being triggered then I do a "Post to a web address or MQTT server" which triggers an event on HS. At this point I narrowed it down to where I believe HS is not part of the problem. So here is where I am at this point:
When I go to the Trigger tab of camera properties and I click on "Trigger now" I see a red frame around the video stream and the red dot in the top right of the video stream is lighting up. Hence, it seems the camera is indeed being triggered.
When I go to the Alerts tab of camera properties, click on "Configure..." for "Post to a web address or MQTT server" and then click on "Test" then I see a message coming in to HS. So the connection between BI and HS is working.
Hence, for some reason, although the camera gets triggered no alert is being executed.
