first return that junk foscam....Hi Everyone,
I just added a new Fiscal 9900 and for some reason it wont record contiously like my others do. It will record for 10sec and then stops.
Anyone have any ideas?
Thanks T
To add to that I have tried everything, RTSP, different stream rates, dropping it down to 720p. Nothing I cannot get this one out of 8 cams to record.
Blue iris is run and supported by a single person..email from a standard account such as gmail...I have it set to continuous? Also sorry I am assuming the guys are busy but what is the best way to get a hold of support? I emailed them almost 10 days ago but no response yet.
Thanks T
did you actually delete the camera and set it up fresh?Tried that no luck![]()
post an image of the cameras web interface video tab..So I changed it to Re-Encode from direct-to-disk and it works. The only issue with direct-to-disk is that I get artifacts hence why I am not doing it that way for any of the other 7 camera;s. Any idea's?
you didnt follow instructions...you changed the http port...go back..reset the camera and DONT CHANGE ANY PORTS.Factory reset the Cam and just changes IP, User/Pass. Then I deleted the camera and re-added it with a new name. Only settings added was direct, IP:88 and find. Still not recording with direct only when re-encoding is on![]()
