use need to setup a username and password in blue iris options>users.Want to try the BI Web Interface (UI3) but after putting in Remote/internal (LAN) access address I get a connection asking for my "Username" and "Password". I don't recall ever entering anything when installing BI. Where can I get this???
Webserver tabI exceeded the max amount of tries guessing at passwords I might of used to find out it was totally diff now it says exceeded max attempts. After finding this post it’s super easy to find just didn’t know what I was looking for. How do I get to try again or is it just a specified time I’m blocked?
It will work locally because you're using a different IP... Simply need to unblock the blockJust realized it only works while on my home wifi. If I turn wifi off and go cellular it just times out. I’m using port forwarding with stunnel should it still work or what am I missing?
why not? its just being blocked by blue iris for the reasons you stated. Not sure why you have not followed directions to resolve it.By the sounds of it this is where stunnel can’t be used. My router isn’t capable of VPN. I assume my option is to get a capable router. Just when I thought I didn’t need too. I’m such a noob to all of this. Thx for the help
