Hello,
I will be upgrading from Milestone Xprotect Essential+ for my home security system after becoming disillusioned by their licensing system - even the free version (Essential+) was complaining about camera licenses being in "grace period" from their licensing system thinking they were new cameras after a firmware update. Free is free, I shouldn't have to pay for free software just because I update my firmware (but I digress...)
One reason I stuck with Milestone as long as I did is because it appears to be a bit more conservative with CPU, the built-in video motion detection (VMD) wasn't very CPU-intensive and I read it can slow FPS down considerably in the Blue Iris cliff notes
So I'm researching if it's possible to use the camera's VMD data through a metadata connector to record VMD events from the camera in Blue Iris. Is this something that's possible?
I guess I should start by asking if my cameras are natively supported or must be connected through ONVIF driver - a few are cheap Hikvision knock-offs from Anpviz, but I also have 2x Dahua T5442TM-AS and 1x HFW1831C-PIR
Does ONVIF metadata connection supports VMD data in BI... ?
I haven't seen any threads in my search discussing this, so I thought I'd up a post. Thanks
