Blue Iris Version 5 Simplified Manual for Web Server GUI - Is one available?
Alaska Country
Getting comfortable
Jun 10, 2021
659
916
Alaska
BI is setup so that the wife can also use the Web Server GUI, on her Windows 10 computer to view clips, time lines, etc. The "official" version 5 manual works well for those into the hardware and setup aspects of BI but is technical for use as a "Users" manual.
However, looking a "Users" manual that is non technical, addresses the issues of what the icons indicate, how to change available settings, view video, etc.
Is there such a manual out there that is available for download?
Also found that using a Windows 10 bat file helps in launching Edge and opening up the login page for the Web Server that is easy for the wife to use.
You and your wife might find the following webinar on the Blue Iris web interface (UI3) is what you're looking for.
