- Mar 3, 2018
- 4
- 0
newest release says xp is fixed...you should not be using xp anyway..Having the same problem with XP with last update Version 4.7.0.1 (March 5, 2018) - won't restart
you can pickup a windows 10 pc that will blow away your older xp system and use much less power for only about 100 dollars...Thanks - been planning to move it to another computer
if you are exposing the machine to the internet you are asking for trouble...its completely vulnerable....also you are likely using more power on that old machine than it would cost to replace it ....so you are paying your electric company instead of yourself..Hey thanks for the reply - I run blue iris and my web server on this XP machine, I have other machines ready but this old XP been running 10 years or so, just waiting on it to stop running it just stubborn like me
This was a post from 2014:if you are exposing the machine to the internet you are asking for trouble...its completely vulnerable....also you are likely using more power on that old machine than it would cost to replace it ....so you are paying your electric company instead of yourself..
yesThis was a post from 2014:
Welcome to the forum....make sure you have your license key.
Go to blue iris options about
Export your settings
Deactivate your account.
Import settings on new pc
enter license key.
Still good to move to another machine using these steps?
what http update are you talking about?I avoided the HTTP update as long as I could,, because I knew there would be issues...
A couple nights ago, I allowed the updates to continue and of course that included the HTTP update, and as expected, now via my HTMLs I am no longer able to view the cameras..
I used to be able to pull images using "http://DOMAIN:port#/image/Camera#". but since the update, nothing.
What has happened this time ??
clipbrd
