Hello I have Blue Iris 5 that I have set up with 8 cameras, all recording continuously. Mostly Foscam/Amcrest cameras. I am having an issue where on all of the cameras that I checked the time skips from 2:00 am to 2:06 am every morning. The camera time and Blue Iris time both skip ahead consistently 6 minutes and 30 seconds. I have both POE and ethernet connected powered cameras.
I first noticed this when I had a motion security light that came on each night at exactly 2:00 am. I then was looking at the camera nearby to see what the trigger was. I then noticed the skip. I have checked several of the other cameras, both POE and powered, with the same results. This seems to have been happening for as long as I have records for. I thought it was some type of power glitch, but do not know how that would affect things. I have a UPS on the Blue Iris computer, as well as a backup generator (neither of these has been activated).
I have checked to make sure that I am not running out of recording size (largest file for one camera was 4 GB, and cut video recording was set to 10.5 GB), so that does not seem to be the issue.
I am going to try an experiment where I record a digital clock to verify that indeed this is skipping recording.
Has anyone else seen anything similar to this? I have searched the forums and not seen anything like this, but I may have missed it.
I have attached files showing the setup for the first camera that I noticed this on.
Thanks for your help.
